AstroVox :: Επισκόπηση Θ.Ενότητας - Λυρίδες - Μέγιστο 22 Απριλίου
Δημοσίευση νέας  Θ.Ενότητας   Απάντηση στη Θ.Ενότητα    AstroVox Forum Αρχική σελίδα -> Παρατήρηση κομητών, αστεροειδών, μετεώρων
akisnOffline
Ένταξη: 01 Σεπ 2011
Σύνολο δημοσιεύσεων: 141
Τόπος: Τρίκαλα
Ηλικία: 14
ΔημοσίευσηΔημοσιεύθηκε: 09/04/2012, ημέρα Δευτέρα και ώρα 15:03    Θέμα δημοσίευσης: Λυρίδες - Μέγιστο 22 Απριλίου
Από 16 Απρ 2012 έως και 25 Απρ 2012
Παράθεση:
Active: April 16—25; Maximum: April 22, 05h30m UT (λ⊙ = 32.32°), but may vary
ZHR = 18 (can be variable, up to 90);
Radiant: α = 271°, δ = +34°; Radiant drift: see Table 6;
V∞ = 49 km/s; r = 2.1;
TFC: α = 262°, δ = +16° and α = 282°, δ = +19° (β > 10° S).
Παράθεση:
The λ⊙ = 32.32° timing given above is the 'ideal' maximum found in IMO results from 1988—2000. However, the maximum time was variable from year to year between λ⊙ = 32.0°—32.45° (equivalent to 2012 April 21, 21h30m to April 22, 08h30m UT). Activity was variable too. A peak at the ideal time produced the highest ZHRs, ∼ 23, while the further the peak happened from this, the lower the ZHRs were, down to ∼ 14. (The last very high maximum was in 1982, when a shortlived ZHR of 90 was recorded.) The mean peak ZHR was 18 over the thirteen years examined.
While generally thought of as having a short, quite sharp, maximum, this investigation showed the shower's peak length was inconstant. Using the Full-Width-Half-Maximum time (the period ZHRs were above half the peak level), a variation between 14.8 to 61.7 hours was detected (mean 32.1 hours). The best rates are normally achieved for just a few hours even so. The analysis also confirmed that occasionally, as their highest rates occurred, the Lyrids produced a brief increase in fainter meteors. Lyrids are best viewed from the northern hemisphere, but are visible from many sites north and south of the equator. As the radiant rises during the night, watches can be carried out usefully after about 22h30m local time from mid-northern sites, but only well after midnight from the mid-southern hemisphere. New Moon on April 21 makes this year perfect for Lyrid maximum observing, and if the ideal peak time recurs, it should be best-seen from sites across much of North America, particularly the eastern half. Remember, other maximum times are perfectly possible!
(http://www.imo.net)
Οι Λυρίδες είναι μια βροχή διαττόντων αστέρων η οποία είναι ορατή από τις 16 έως τις 25 Απριλίου και το μέγιστο της βροχής είναι στις 22 Απριλίου. Κατά μέσο όρο στο μέγιστο πέφτουν 18 διάττοντες/ώρα με ταχύτητα 49km/s. Φέτος το μέγιστο πέφτει την Κυριακή του Θωμά και η σελήνη θα βρίσκεται σε φάση νέας σελήνης. Οπότε είναι μια καλή ευκαιρία να δούμε μια θεαματική βροχή αστεριών. Dancing
Διάγραμμα για την συχνότητα των Λυρίδων το 2011
 Μέγεθος αρχείου:  6.21 KB
 Διαβάστηκε:  2602 φορές
Ακτινοβόλο σημείο
 Μέγεθος αρχείου:  40.88 KB
 Διαβάστηκε:  139 φορές
jlaskOffline
Ένταξη: 08 Νοέ 2009
Σύνολο δημοσιεύσεων: 31
Τόπος: Ηράκλειο
Ηλικία: 31
ΔημοσίευσηΔημοσιεύθηκε: 19/04/2012, ημέρα Πέμπτη και ώρα 9:54    Θέμα δημοσίευσης: Απάντηση με παράθεση αυτού του μηνύματος
Ελπίζω να μας ευνοήσει ο καιρός το σαβ/κο για να γίνει και η παρατήρηση-καταγραφή του φαινομένου. Η παρατήρηση των Λυρίδων δίνει μιας πρώτης τάξεως ευκαιρία σε συνδιασμό με το νέο φεγγάρι, τουλάχιστον για μένα, να παρατηρηθεί και ο αστερισμός της Λύρας και του Ηρακλή που αργούν να κάνουν την εμφάνιση τους στον ουρανό. 1-2 ώρες θα αφιερώσω στην καταγραφή των διαττόντων και μετά θα στρέψω το βλέμμα μου στην Λύρα και στον Ηρακλή. Οπότε, εντάσσονται στο πρόγραμμα παρατήρησης τα M13 & Μ92 στον Ηρακλή όπως και η παρατήρηση και η εκτίμηση της λαμπρότητας του β και R Λύρας.
vtsamisOffline
Ένταξη: 29 Μάρ 2001
Σύνολο δημοσιεύσεων: 1920
Τόπος: Χαλάνδρι Αττικής
Ηλικία: 45
ΔημοσίευσηΔημοσιεύθηκε: 19/04/2012, ημέρα Πέμπτη και ώρα 11:19    Θέμα δημοσίευσης: Απάντηση με παράθεση αυτού του μηνύματος
Ωραίο θέμα! Η καλύτερη ώρα για παρατήρηση - καταγραφή είναι το δεύτερο μισό της νύχτας Σαββάτου προς Κυριακή, κυρίως προς τα ξημερώματα λίγο πριν χαράξει, καθώς το μέγιστο αναμένεται στις 08:30 Ώρα Ελλ. (22/4/2012)
Lyrid Meteors και ISS
Πιο ευνοημένη είναι η Β. Αμερική. Εκεί θα επιχειρηθεί τριπλή καταγραφή διαττόντων με video, κατά τη διάρκεια του μεγίστου, από: ερασιτέχνες στη Γη, από ένα αερόστατο στην περιοχή της Καλιφόρνιας και από τον ISS, με τον αστροναύτη Don Petit, ο οποίος τυγχάνει να είναι και ερασιτέχνης αστρονόμος.
Η τελευταία ορατή διέλευση του ISS πάνω από την Ελλάδα πριν το μέγιστο θα γίνει αρκετές ώρες νωρίτερα, το βράδυ του Σαββάτου περίπου στις 23:09. Ο ISS τότε θα είναι καλύτερα ορατός από τη Β. Ελλάδα (στον Πάρνωνα θα είναι πολύ χαμηλά, γύρω στις 10 μοίρες ΒΒΔ).
Όσοι τον δείτε, σκεφτείτε ότι μέσα ο Don Petit θα ετοιμάζεται να καταγράψει Λυρίδες στις επόμενες ώρες, πάνω από τη Β. Αμερική!
Για στοιχεία διέλευσης του ISS: http://www.heavens-above.com/
Βαγγέλης
Η πληροφόρηση από τον Τόλη έγραψε:
Note: A graphic showing the ISS ground track near the time of the Lyrid
peak is available at
http://fireballs.ndc.nasa.gov/Lyrids_ISS_22Apr0510UT.bmp
Regards,
Bill Cooke
Lead, NASA Meteoroid Environments Office
Διέλευση του ISS πάνω από την Ελλάδα, Σάββατο 23:09
 Μέγεθος αρχείου:  62.82 KB
 Διαβάστηκε:  121 φορές
konstantinosfOffline
Νέος
Ένταξη: 12 Απρ 2012
Τόπος: ΑΘΗΝΑ
Ηλικία: 43
ΔημοσίευσηΔημοσιεύθηκε: 19/04/2012, ημέρα Πέμπτη και ώρα 15:26    Θέμα δημοσίευσης: Απάντηση με παράθεση αυτού του μηνύματος
Σας ευχαριστούμε πολύ όλοι οι νέοι του site για τις πληροφορείες που μας δίνετε. Αν φανώ προσωπικά κουραστικός ζητάω συγνώμη εκ των πρωτέρων.Όσο αφορά τους διάτοντες για το ξημέρωμα της Κυριακής θα ήθελα να ρωτήσω με ενα ζευγάρι κυάλια τι θα μπορέσω να δω που να κοιτάω και τι ώρες. σας ευχαριστώ.
vtsamisOffline
Ένταξη: 29 Μάρ 2001
Ηλικία: 45
ΔημοσίευσηΔημοσιεύθηκε: 19/04/2012, ημέρα Πέμπτη και ώρα 19:00    Θέμα δημοσίευσης: Απάντηση με παράθεση αυτού του μηνύματος
Δε χρειάζεσαι κιάλια ή τηλεσκόπιο για τους διάττοντες. Τους παρατηρούμε με τα μάτια, δια γυμνού οφθαλμού.
Γενικά καθόμαστε στα ζεστά (πχ ή τελείως ξάπλα στρωματσάδα ή σε άνετη καρέκλα) και παρατηρούμε σταθερά μια περιοχή του ουρανού κεντράροντας το βλέμμα μας λίγο αριστερά ή λίγο δεξιά από το ακτινοβόλο σημείο (περίπου 50-60 μοίρες), ώστε το έχουμε στην άκρη του οπτικού μας πεδίου. Έτσι καταλαβαίνουμε καλύτερα την προέλευση κάποιου διάττοντα, αν είναι "δικός μας" (στην προκειμένη περίπτωση Λυρίδης) ή αν ανήκει σε άλλη βροχή, αν δηλαδή προέρχεται από άλλο ακτινοβόλο σημείο.
Μετά τα μεσάνυχτα του Σαββάτου το ακτινοβόλο σημείο θα είναι αρκετά ψηλά, 30 μοίρες ανατολικά, ώστε να αρχίσει να δίνει κάποιους λίγους και αραιούς διάττοντες. Τότε μπορούμε να παρατηρούμε είτε προς ΒΑ ή προς ΝΑ ή νότια.
Το πού ακριβώς κοιτάμε βέβαια δεν είναι και απαράβατος κανόνας. Ειδικά μετά τις 02:30 - 03:00 οπότε το ακτινοβόλο σημείο θα είναι ήδη πολύ ψηλά στον ουρανό, και όσο περνάει η ώρα θα κινείται προς το ζενίθ (το σημείο του ουρανού πάνω από το κεφάλι μας), πραγματικά μπορείς να κοιτάς σε οποιαδήποτε περιοχή του ουρανού σε βολεύει. Τότε, λίγο πριν χαράξει, αναμένεται να φανούν οι περισσότεροι, αλλά μην περιμένετε και τρελλά νούμερα. Τα πολλά θα τα χάσουμε και θα τα δούν οι Αμερικανοί ενώ εδώ θα είναι μέρα. Προσοχή στο σβέρκο!
Βαγγέλης
Ἀστέρας εἰσαθρεῖς, Ἀστὴρ ἐμός· εἴθε γενοίμην οὐρανός, ὡς πολλοῖς ὄμμασιν εἰς Σὲ βλέπω.
Πλάτων
Bi2LOffline
Ένταξη: 05 Απρ 2004
Σύνολο δημοσιεύσεων: 5983
Τόπος: Corfu, Greece
ΔημοσίευσηΔημοσιεύθηκε: 20/04/2012, ημέρα Παρασκευή και ώρα 14:40    Θέμα δημοσίευσης: Απάντηση με παράθεση αυτού του μηνύματος
Κωνσταντίνε έτσι ακριβώς όπως τα λέει ο Βαγγέλης, απλά να ξέρεις ότι μέσα απ'την πόλη μην περιμένεις να δεις κάτι ιδιαίτερο.
Βαγγέλη πολύ ωραία πληροφορία για τον Don Petit, ευχαριστούμε Wink
Εμείς εδω θα κάνουμε καταγραφή και θα δοκιμάσω την τύχη μου με το ufo capture, επιτέλους ο καιρός αρχίζει να φτιάχνει Very Happy
Βασίλης Μεταλληνός
OO 16 1600 f4 Dob
ΟΟ 12.5 1525 f4.8 NEQ6
TOA130 1000 f7.7 Temma2 OTASC
ED80 600 f7.5, PST/Coronado, Vixen9x63
Canon 40D 400D 30D, Qhy5, wat120n+
2009年7月22號日食 http://astrocorfu.blogspot.com
akisnOffline
Ένταξη: 01 Σεπ 2011
Τόπος: Τρίκαλα
Ηλικία: 14
ΔημοσίευσηΔημοσιεύθηκε: 21/04/2012, ημέρα Σάββατο και ώρα 13:43    Θέμα δημοσίευσης: Απάντηση με παράθεση αυτού του μηνύματος
konstantinosf έγραψε:
Γενικώς είναι πολύ δύσκολο να πιάσεις διάττοντα με τηλεσκόπιο αλλά με κιάλια είναι σχετικά εύκολο. Βέβαια όπως είπε και ο κύριος astrovox πιο πάνω το καλύτερο είναι να ξαπλώσεις σε μια ρυθμιζόμενη ξαπλώστρα(ανάλογα σε ποιο σημείο του ουρανού βρίσκεται το ακτινοβόλο σημείο), να έχεις μία κουβέρτα και ένα ζεστό ρόφημα και είσαι έτοιμος να απολαύσεις την βροχή.
Bi2LOffline
Ένταξη: 05 Απρ 2004
ΔημοσίευσηΔημοσιεύθηκε: 21/04/2012, ημέρα Σάββατο και ώρα 19:13    Θέμα δημοσίευσης: Απάντηση με παράθεση αυτού του μηνύματος
Μην μπερδευτεί κανείς, σήμερα ξημερώματα 22 Απριλίου είναι το μέγιστο και απο ότι φαίνεται ο καιρός μας χαμογέλασε (τουλάχιστον εδω στα ΒΔ έχει καθαρίσει).
Καλή παρατήρηση σε όλους Razz
Βασίλης Μεταλληνός
OO 16 1600 f4 Dob
akisnOffline
Ένταξη: 01 Σεπ 2011
Τόπος: Τρίκαλα
Ηλικία: 14
ΔημοσίευσηΔημοσιεύθηκε: 21/04/2012, ημέρα Σάββατο και ώρα 21:24    Θέμα δημοσίευσης: Απάντηση με παράθεση αυτού του μηνύματος
Υπολόγισα ότι το ακτινοβόλο σημείο ανατέλλει περίπου στις 21:20 και φτάνει στον ζενίθ στις 5:45. Καλές παρατηρήσεις σε όλους!!!
akisnOffline
Ένταξη: 01 Σεπ 2011
Τόπος: Τρίκαλα
Ηλικία: 14
ΔημοσίευσηΔημοσιεύθηκε: 22/04/2012, ημέρα Κυριακή και ώρα 11:39    Θέμα δημοσίευσης: Απάντηση με παράθεση αυτού του μηνύματος
Καλημέρα!!!
Χθες κατάφερα να δω 4 Λυρίδες μέχρι περίπου τις 2:30 το πρωί. Είδα επίσης έναν διάττοντα ανατολικά του Κύκνου περίπου. Μήπως ξέρει κανείς από ποια βροχή είναι αυτό;
jlaskOffline
Ένταξη: 08 Νοέ 2009
Τόπος: Ηράκλειο
Ηλικία: 31
ΔημοσίευσηΔημοσιεύθηκε: 23/04/2012, ημέρα Δευτέρα και ώρα 10:04    Θέμα δημοσίευσης: Απάντηση με παράθεση αυτού του μηνύματος
Είδα και εγώ 6 λυρίδες (22/4, 2:00-3:30), αλλά μετά μου τα χάλασε ένα σύννεφο που μπήκε μπροστά και δεν έλεγε να φύγει με αποτέλεσμα η παρατήρηση να συνεχιστεί σε άλλη περιοχή του ουρανού. Πάντα όμορφος ο ανοιξιάτικος νυχτερινός ουρανός.
Bi2LOffline
Ένταξη: 05 Απρ 2004
ΔημοσίευσηΔημοσιεύθηκε: 23/04/2012, ημέρα Δευτέρα και ώρα 14:40    Θέμα δημοσίευσης: Απάντηση με παράθεση αυτού του μηνύματος
Δυστυχώς σε εμάς εδώ μας τα χάλασε λίγο ο καιρός αφού μετα τις 00:00 ο ουρανός άρχισε να κλείνει Sad
Συνολικά είδαμε περισσότερους απο 20 διάττοντες, αλλά είχαμε νεφοκάλυψη 50% απ'τις 22:00 και μετα τις 00:00 είχαμε 80-99%,
Δυστυχώς μείναμε εως τις 03:00 και μετα φύγαμε, κρίμα τόσος εξοπλισμός που ανέβασα στο βουνο για καταγραφή.
Βασίλης Μεταλληνός
OO 16 1600 f4 Dob
akisnOffline
Ένταξη: 01 Σεπ 2011
Τόπος: Τρίκαλα
Ηλικία: 14
ΔημοσίευσηΔημοσιεύθηκε: 14/05/2012, ημέρα Δευτέρα και ώρα 19:35    Θέμα δημοσίευσης: Απάντηση με παράθεση αυτού του μηνύματος
Διάγραμμα για την συχνότητα των Λυρίδων την φετινή χρονιά
 Μέγεθος αρχείου:  5.71 KB
 Διαβάστηκε:  1603 φορές
Δημοσίευση νέας  Θ.Ενότητας   Απάντηση στη Θ.Ενότητα    AstroVox Forum Αρχική σελίδα -> Παρατήρηση κομητών, αστεροειδών, μετεώρων Όλες οι Ώρες είναι UTC + 3
