βολιωτης Δημοσιεύτηκε Σεπτέμβριος 15, 2006 Μοιραστείτε Δημοσιεύτηκε Σεπτέμβριος 15, 2006 giorgosgr μη με δειρεις Προσωπικα προτιμω να βολταρω εκει περα χειροκινητα .Ειναι πιο ομορφο . Απο το Virtual Moon Atlas Quick user's guide . How to find an unknown lunar formationthat you just discover the existence(Basic or Expert version with a "Goto" mount) You have just dicover in a magazine or in a book about the Moon, the existence of an interesting lunar formation you just don't know the existence before. If you own a computerized "Goto" mount which accepts the ASCOM protocol, the Virtual Atlas of the Moon will track it directly on the Moon. First of all be sure that you have installed the good ASCOM drivers on your computer. If not, go on the internet to the sitehttp://ascom-standards.org/ to download them. Install them. Connect your mount to your computer Start your computer and the "Basic" or "Expert" version of the software. First initialize tour telscope as usually, then use the pad or a planetarium software to point the Moon. Click on the "See the menu" button and launch the connection. Begin centering a well known formation in the eyepiece fieeld and select it on the map. Push the "Sync selection" button for initializing telescope coordinates on this position. It's also possible to make this operation on a star near the Moon with the planetarium program. After, check the box "Follow position" so that the map displays always the telescope position. If your telescope can do automatic pointing, you can now click on a formation on the map, or choose it with the "Search" function of the "Information" thumbnail and then click on the "Goto selection" button Τα πάντα ειναι Μαθηματικά. Σύνδεσμος για σχόλιο Κοινή χρήση σε άλλους ιστότοπους More sharing options...
nickthegreek13_7 Δημοσιεύτηκε Σεπτέμβριος 15, 2006 Μοιραστείτε Δημοσιεύτηκε Σεπτέμβριος 15, 2006 Χεχε, μου θύμησες εναν απο το YIM που δεν είχε ιδέα οτι το καταδιοπτρικό του απο την Meade είχε Go-To επίσης για την Σελήνη και τώρα το χρησιμοποιεί ανελειπώς Σύνδεσμος για σχόλιο Κοινή χρήση σε άλλους ιστότοπους More sharing options...
giorgosgr Δημοσιεύτηκε Σεπτέμβριος 15, 2006 Μοιραστείτε Δημοσιεύτηκε Σεπτέμβριος 15, 2006 Οσο να κανεις troubleshooting με εναν απλο χαρτη και λευκο φακο (σεληνη βλεπουμε δεν εχουμε νυχτερινη οραση) θα αναγνωριζουμε ο,τι θελουμε στην επιφανεια της Βεβαια απο την αλλη το goto ισως βοηθησει καποιους που δεν μπορουν καν να βρουν τη σεληνη ετσι Facebook Giorgos'' videoastronomy page https://www.facebook.com/videoastronomy/ Σύνδεσμος για σχόλιο Κοινή χρήση σε άλλους ιστότοπους More sharing options...
nickthegreek13_7 Δημοσιεύτηκε Σεπτέμβριος 15, 2006 Μοιραστείτε Δημοσιεύτηκε Σεπτέμβριος 15, 2006 Βεβαια απο την αλλη το goto ισως βοηθησει καποιους που δεν μπορουν καν να βρουν τη σεληνη ετσι. Σίγουρα υπάρχουν κάτι τέτοιοι Σύνδεσμος για σχόλιο Κοινή χρήση σε άλλους ιστότοπους More sharing options...
βολιωτης Δημοσιεύτηκε Σεπτέμβριος 16, 2006 Συγγραφέας Μοιραστείτε Δημοσιεύτηκε Σεπτέμβριος 16, 2006 Προτιμω να μην ειναι αυτοματοποιημενη η βολτιτσα μου εκει πανω . Ο λογος ειναι μαλλον ο ιδιος με εσας των ντομπσοναδων που δε θελετε goto . Τα πάντα ειναι Μαθηματικά. Σύνδεσμος για σχόλιο Κοινή χρήση σε άλλους ιστότοπους More sharing options...
