Κυκλοφόρησε μόλις η έκδοση 3.6 του Cartes du Ciel με διάφορες μικροαλλαγές αλλά και διορθωμένη και πληρέστερη ελληνική μετάφραση. Μπορείτε να το κατεβάσετε εδώ:
http://www.ap-i.net/skychart/en/download
Version 3.6 release Notes
- Change the way the "Show grid" buttons are working.
- Add "Show compass" button.
- Add distance measurement tool, add "Measure distance" button.
- Add chart legend. See menu Chart / Labels
- Change in projection mapping:
- Add Mercator projection.
- Cartesian and Mercator projection are rotated to the screen center for full sky coverage.
- Change the default projection to Tangent for FOV up to 90 deg. and Mercator for wider fields.
- Limit the use of Arc projection to 250 deg. FOV.
- Limit the vision of objects below the horizon to 180 deg. FOV.
- New default star catalog based on Extended Hipparcos to replace the BSC and Sky2000.
- Improved precision of the apparent coordinates (many thanks to P. Wallace for its help):
- Star parallax
- Take account of the radial velocity to compute the proper motions.
- Light deflection by the Sun.
- Extended time validity for nutation and aberration if using DE422.
- Allow to use Socks proxy.
- Improved precision in the display of FITS images by using WCStools. Can show the images with transparency.
- Add option to only show the meridian lines.
- Increase planet simulation up to 500 positions, no change for comets and asteroids.
- Add user defined objects in catalog setting.
- Can change the color for lines and nebulae from the catalog setting.
- New online Internet resources:
- Add any catalog from Vizier
- Search Simbad, NED, Vizier
- Link object detail to Simbad, NED, HyperLeda
- Extend the allowed date to +/- 200'000 years
- Compute the precession using "New precession expressions, valid for long time intervals, J. Vondrak, 2011"
- Compute DeltaT values from "Five Millennium Canon of Solar Eclipses, Espenak & Meeus, 2006"
- Add Tirion constellation figures created by James Trogolo
Ευχαριστούμε για την ενημέρωση. Κάθε φορά γίνεται ακόμη καλύτερο.
Φιλικά - Ντίνος Μακρόπουλος
Prem Rawat
  • 5 μήνες αργότερα...
Πάρα πολύ καλό! Το κατέβασα και το φόρτωσα με όλα τα καλούδια. Πλήρως ελληνικό μενού! Θέλει αρκετό ψάξιμο βέβαια μέχρι να αρχίσεις να το "κατακτάς".
Ο ΣΚΥΛΟΣ ΤΩΝ ΑΣΤΡΩΝ
