ΠΩΛΕΙΤΑΙ Η ΚΑΜΕΡΑ FLI MICROLINE ML8300C ΕΓΧΡΩΜΗ ΚΑΙ ΥΔΡΟΨΥΚΤΗ. Η ΘΕΡΜΟΚΡΑΣΙΑ ΠΟΥ ΜΠΟΡΕΙ ΝΑ ΕΠΙΤΕΥΧΘΕΙ ΕΙΝΑΙ -45 ΒΑΘΜΟΙ ΚΕΛΣΙΟΥ, ΑΡΚΕΤΗ ΝΑ ΜΕΙΩΘΕΙ Ο ΘΟΡΥΒΟΣ ΤΟΥ CCD ΣΤΟ ΕΛΑΧΙΣΤΟ.
ΤΙΜΗ: 1800 ΕΥΡΩ
ΓΙΑ ΠΕΡΙΣΣΟΤΕΡΕΣ ΠΛΗΡΟΦΟΡΙΕΣ: WWW.FLICAMERA.COM
FLI ML8300-41-C - MicroLine KAF-8300 Color CCD Camera with 41mm Shutter
This Front-Illuminated FLI MicroLine CCD Camera features the Kodak KAF-8300 Color Sensor, with a 3326 x 2504 array, 5.4um pixel size, peak quantum efficiency of 0.41, no micro-lensing, an IR blocked window and 41mm shutter.
CCD can be operated at -30° deg C with typical room temperatures and without the need for water cooling or special cooling sequences.
The FLI MicroLine CCD Camera is CNC machined with only the highest quality electrical components and circuit boards.
Compatible with all FLI imaging accessories, including the Precision line of Color Filter Wheels and Digital Focusers. MicroLine camera adapters are available for microscope, telescope and machine vision connectivity.
Options for this camera includes liquid cooling.
About the FLI MicroLine CCD Camera Series...
Goodbye Goliath! MicroLine CCD cameras are smaller and lighter-weight than the competition, but outperforms them in key areas such as noise, frame quality, download speeds, bit-depth, and CCD cooling.
FLI MicroLine CCD cameras feature fast download speeds that simply leave the competition behind. Each component of the FLI MicroLine camera is designed and manufactured for a long life in the most demanding conditions. All major components are CNC machined and you're looking at only the highest quality electrical components and circuit boards with logo, serial number and focal plane indicators laser-etched on the surface - not printed. FLI designed photo-etched stainless-steel shutters are field-serviceable should they ever encounter damage and the sensor is hermetically sealed from dust and moisture.
What sets FLI MicroLine CCD Cameras apart is their small form factor. At 3.7 x 3.7 x 5 inches (HWL), the FLI MicroLine is a small camera with big camera capabilities! The Microline improves upon the highly successful FLI MaxCam design in a number of key areas including cooling, download speeds, clear aperture, and sensor capability.
Now, let's talk about FLI MicroLine CCD Camera Cooling... The FLI MicroLine’s robust cooling design achieves a sustainable cooling performance of 50-55° deg C below ambient. The camera’s CCD can be operated at -30° deg C with typical room temperatures and without the need for water cooling (sold as a separate option, visit the Accessories section for a list of choices) or special cooling sequences. Simply set the MicroLine cooling where you want it and the camera will do the rest – quickly and worry-free.
Conventional imaging cameras move the image data directly from the image sensor to the USB port, making them susceptible to added artifacts due to PC processing tasks, processor speed, and other PC-related issues. The MicroLine avoids these issues with its internal frame buffer, thus allowing an image to be quickly read out and downloaded to the PC. This allows the PC to take the image at whatever speed it is capable of without introducing any artifacts to the image.
When it comes the FLI MicroLine, you get system compatibility and mounting options as well as mechanical shutter, liquid cooling, and Anti-Dew Technology options that will help you trick out your camera the way you want it. The MicroLine line of CCD cameras is compatible with all FLI imaging accessories, including the Precision line of Color Filter Wheels and Digital Focusers. MicroLine camera adapters are available for microscope, telescope and machine vision connectivity. Scroll down for a list of available time-of-purchase options for this camera model and sensor combination.
FLI MicroLine CCD Camera Series Features in a Nutshell..
Storage temperature range: -50°C to +100°C - Operation temperature range: -40°C to +50°C - Relative humidity operating range: 95%
Heavy weight performance in a 2.8 lbs package with Liquid and Air Cooled bases
RBI Annihilator Standard and AR Coated Windows
Video mode with interline sensors and Small Footprint (3.7 x 3.7 x 5in.)
Power requirements: 12V - Reaches operating temperatures in 5 minutes!
Ideal for X-ray Applications, Astronomical Imaging, Scientific Imaging, Medical Applications, and Forensic Applications.
About the Kodak KAF-8300 Sensor...
The Kodak KAF-8300 Image Sensor is a 22.5mm diagonal (Four Thirds Format) high performance color or monochrome full frame CCD (charge-coupled device) image sensor designed for a wide range of image sensing applications including digital imaging.
Each pixel contains blooming protection by means of a lateral overflow drain thereby preventing image corruption during high light level conditions. For the color version, each of the 5.4μm square pixels are patterned with an RGB mosaic color filter with overlying microlenses for improved color response and reproduction. Several versions of monochrome devices are available with or without microlenses.
Kodak KAF-8300 Imaging Sensor Features
High Resolution - High Dynamic Range - Low Noise Architecture
Photography, Industrial Imaging and Medical Imaging Applications
Quantum Efficiency, color: R(600nm), G(540nm), B(480nm) 33%, 40 %, 33% - Quantum Efficiency, monochrome: Microlens, clear glass (540nm) Microlens, no glass (540nm) Microlens, AR glass (540nm) No Microlens, clear glass (560nm): 54% 60% 56% 37%
Dark Signal: < 200 e-/s - Dark Current Doubling Temperature: 5.8 °C - Linear Dynamic Range: 64.4 dB - Linearity Error at 12ºC +/- 10%
Active Image Size: 17.96mm (H) x 13.52mm (V) 22.5mm (diagonal) - Aspect Ratio: 4:3
Blooming Protection: (1ms integration time) 1000x saturation exposure - Maximum Data Rate: 28 MHz
Available Options For This FLI MicroLine Camera System...
Standard Liquid Cooling Option: For applications that require the ultimate in cooling and/or require heat dissipation to occur away from the camera body.
Liquid Cooling Option with Double Shut-Off: For applications that require the ultimate in cooling and/or require heat dissipation to occur away from the camera body but with the added feature of double-shut off valves.
Liquid Cooling Option with Dry Disconnect: For applications that require the ultimate in cooling and/or require heat dissipation to occur away from the camera body but with the added feature of dry disconnect valves.
If you would like any of the options listed in the above information, please either click on the links and then add your choices to your shopping cart, or visit the Accessories section to see a full list of options. If you aren't sure which options are best for your set-up, please feel free to contact us by email or phone at 1-800-483-6287 and we will be happy to put together a custom package just for you! Thank you.
FLI Product Number: FL-ML8300-41-C
