πηγη imo.net
http://www.imo.net
http://www.imo.net/docs/cal2010.pdf
Perseids (PER)
Active: July 17–August 24; Maximum: August 12, 23h30m to August 13, 02h00m UT
(λ⊙ = 140 .◦0–140 .◦1), but see text; ZHR = 100;
Radiant: α = 48◦, δ = +58◦; Radiant drift: see Table 6;
V∞ = 59 km/s; r = 2.2;
TFC: α = 019◦, δ = +38◦ and α = 348◦, δ = +74◦ before 2h local time;
α = 043◦, δ = +38◦ and α = 073◦, δ = +66◦ after 2h local time (β > 20◦ N);
IFC: α = 300◦, δ = +40◦, α = 000◦, δ = +20◦ or α = 240◦, δ = +70◦ (β > 20◦ N).
July to September
The ANT is the chief focus for visual attention during most of July, as its radiant area moves
steadily through eastern Sagittarius, then across northern Capricornus into south-west Aquarius.
Results suggest the Source may not be especially recognisable after the first few days however,
as ZHRs for most of the month seem < 2, and for a time in mid-month even < 1! Activity
appears to improve somewhat, with ZHRs ∼ 2 to 3, by late July and through the first half
of August.
Despite the large ANT radiant area overlapping that of the minor α-Capricornids
(CAP) in July-August, these ZHR levels may make it more practical to still identify CAP
meteors, particularly near the CAP maximum, due around July 30 or 31. That is unlikely to be
the case this year though, due to the waning gibbous Moon in late July.
The δ-Aquariids (SDA) are strong enough, and the Piscis Austrinids (PAU) have a radiant probably distant enough from
the ANT area, that both should still be separable from it too, particularly from the southern
hemisphere. Moonlit maxima are due from both around July 28, the PAU possibly on July 29
instead, while VID indicated the SDA peak might fall alternatively around λ⊙ = 128◦, 2010
July 31.
By the best from the major, moonless, Perseids, and the partly Moon-free κ-Cygnid peak in
mid August, ANT ZHRs will likely have dropped back below 2 again, as the radiant tracks on
through Aquarius, and into western Pisces by the α-Aurigid maximum on the August-September
boundary, probably this year peaking around 07h UT on September 1 (with a very problematic
last quarter Moon). The minor September Perseids are moonless for their likely maximum, but
most of the possible very weak δ-Aurigid peak, perhaps between September 24 to October 4,
will be lost to the bright waning Moon. There have been significant discrepancies found in
these showers’ details as determined by recent video results, as discussed below.
For most of September, ANT rates continue from their radiant in Pisces, albeit with ZHRs probably no better than 2–3, but remember that from September 25, Antihelion meteors are no longer to
be recorded as such, as both Taurid showers take over the near-ecliptic shower baton until
late November. For daylight radio observers, the interest of May-June has waned, but there
remain the visually-impossible γ-Leonids (peak due near August 25, 16h UT, albeit not found in
recent radio results), and a tricky visual shower, the Sextantids. Their maximum is expected on
September 27, around 16h UT, but possibly it may occur a day earlier.
In 1999 a strong return was detected at λ⊙ ∼ 186◦, equivalent to 2010 September 29, while in 2002, the September 27 peak was not found, but one around September 29–30 was! It seems plausible that several minor maxima in early October may also be due to this radio shower. The waning gibbous Moon creates additional difficulties for visual observers hoping to catch some Sextantids in the pre-dawn of late September, though radiant-rise is less than an hour before sunrise in either hemisphere.
The Perseids were one of the most exciting and dynamic meteor showers during the 1990s, with outbursts at a new primary maximum producing EZHRs of 400+ in 1991 and 1992. Rates from this peak decreased to ∼ 100–120 by the late 1990s, and in 2000, it first failed to appear.
This was not unexpected, as the outbursts and the primary maximum (which was not noticed before
1988), were associated with the perihelion passage of the Perseids’ parent comet 109P/Swift-
Tuttle in 1992. The comet’s orbital period is about 130 years, so it is now receding into the
outer Solar System, and theory predicts that such outburst rates should dwindle as the comet
to Earth distance increases. However, predictions suggested 2004–2006 might bring a return of
enhanced rates ahead of the usual maximum, and in 2004 a short, strong peak happened close to
that anticipated pre-peak time.
Activity seemed to be roughly normal in 2005 and 2006 (though
the latter was badly moonlit). IMO observations from the last decade (see HMO p. 145) showed
the timing of the mean or ‘traditional’ broad maximum varied between λ⊙ ∼ 139 .◦8 to 140 .◦3,
equivalent to 2010 August 12, 18h30m to August 13, 07h00m UT, while the shorter, enhanced
filamentary peaks all occurred between λ⊙ ∼ 139 .◦44 to 140 .◦55, 2010 August 12, 09h30m to
August 13, 13h30m UT.
Recent work implies only the ‘traditional’ peak is liable to recur in 2010
(most likely near the nodal crossing time given in the table above), but observers should be
aware of these additional timings as possibilities, and plan their efforts accordingly, just in case!
New Moon on August 10 creates perfect viewing conditions across the peak this year.
The shower is best-observed from mid-northern latitudes, from where the Perseid radiant is usefully
observable from 22h–23h local time onwards, gaining altitude throughout the night.
The nearnodal part of the ‘traditional’ maximum interval would be best-viewed from Europe and North Africa east to central Asia, assuming it happens as expected. All forms of observing can be
carried out on the shower.
For example, video data has been used in recent IMO analyses to
clarify and refine the radiant position for the shower - and to confirm that occasional visual
suspicions the radiant may be multiple were almost certainly only illusory. The only negative
aspect to the shower is the impossibility of covering it from the bulk of the southern hemisphere.
πηγη popastro.com
http://www.popastro.com/sections/meteor/meteor-aug2010.htm
August 2010
August's popularity for UK astronomers stems from it bringing the end of the midsummer overnight twilight season. It is also "Perseid month", as this normally strong major meteor shower peaks in mid August, well-timed to take advantage of the school and college summer holidays. This year, the best Perseid rates should fall nicely overnight for British observers if the predictions prove correct, and better still have no Moon! Nocturnal observing in mid August can be very pleasant, with sometimes quite warm temperatures, and plenty of meteors to see in clear, darker skies. August's weather can be fickle however, on the cusp between late summer and early autumn, thus it can be cold and occasionally frosty by Perseid-time, notably further north in the UK. As always, be prepared before you set out to observe!
Shower of the Month: The Perseids
The Perseid maximum is due between 18:30 UT on August 12 to 07:00 UT on August 13 this year, most likely at some stage from about 23:30 to 02:00 UT. It should produce typical healthy Perseid numbers, with Zenithal Hourly Rates (ZHRs) probably around 100. Unlike in several recent years, no unusual activity is anticipated (though this need not prevent something unexpected happening!). The most plausible peak interval is very favourable for Britain, as the Perseid radiant (illustrated on the accompanying chart) can be usefully-observed from roughly 22h UT onwards here, culminating around 06h, well after dawn. With new Moon on August 10, conditions are ideal to watch whatever takes place - weather permitting. Perseids are swift, often bright, and commonly trained meteors, and those hoping to image some may find their capture rates enhanced by aiming towards And-Cas-Peg-Cyg, aside from recording them passing through some of the more easily-recognisable August constellations that way.
Lower Perseid activity can be followed away from the peak night for most of the month, ending around August 24 (the shower began back in mid July). Moonless skies will be available for at least part of the night once the Perseid radiant is at a suitable elevation from the UK after August 4 or 5, through to about August 21. Post-midnight observing is preferable, when possible, as the radiant is higher in the sky then, thus observed Perseid rates will be also somewhat higher. Activity builds only slowly however, and if it follows its typical pattern, ZHRs will rise above 10 only late in the first week of the month. Observed rates are usually good to very good for a couple of days before the maximum plus a day or so afterwards, with ZHRs tending to drop steeply once the peak is past. This period of better activity is important to remember if it seems the actual maximum may be clouded-out.
ακόμα:
meteorshowersonline.com
http://meteorshowersonline.com/perseids.html
Βασίλης Μεταλληνός
OO 16 1600 f4
ΟΟ 12.5 1525 f4.8 NEQ6
TOA130 1000 f7.7 ΕΜ200
ED80 600 f7.5, Vixen9x63
2009年7月22號日食 - 2017 Aug 21
www.metallinos.net
  • Απαντήσεις 64
Ηδη τα πρώτα στατιστικά ανέβηκαν στο imo.net
http://www.imo.net/node/1295
Αντε να φευγει η Σεληνη σιγά-σιγά να κάνουμε καμια παρατηρηση,
εχει προγραμματίσει κάνεις τίποτα;;
Βασίλης Μεταλληνός
OO 16 1600 f4
www.metallinos.net
Βασίλη, εμείς κάτι έχουμε προγραμματίσει εδώ: http://www.spartastronomy.gr/astroteams/meteors
σε συνεργασία με φίλους και συμπαρατηρητές.
Σε οποιοδήποτε βουνό της Ελλάδας αν βρεθεί όμως κανείς σίγουρα θα απολαύσει πάρα πολλούς διάττοντες, μιας και οι ασέληνες νύχτες φέτος στους Περσείδες προσφέρουν σκοτεινούς ουρανούς και υπόσχονται μεγάλες συγκινήσεις.
Αξίζει να παρατηρήσει κανείς απ' όπου κι αν βρίσκεται!
Βγείτε έξω τα βράδια του Αυγούστου και κοιτάξτε ψηλά! Ιδιαίτερα τις μεταμεσονύκτιες και πρωινές ώρες... :D
Πλάτων
Μια σημείωση για όσους ενδιαφέρονται και για την αισθητική διάσταση
του θέματος:
Οι πιο λαμπροί Περσείδες εμφανίζουν ποικιλία χρωμάτων, λόγω
του οτι οι γραμμές εκπομπής δεν εμφανίζονται ταυτόχρονα.
Αυτά συνήθως απεικονίζονται ικανοποιητικά σε λήψεις με DSLR
δηλ αν κάποιος παίρνει διαδοχικές λήψεις πχ 30 δευτερολέπτων
στο ISO 1600.
Αν δε σταθούμε τυχεροί με κάποιον πολύ λαμπρό Περσείδη, θα
παρακολουθήσουμε το ίχνος του καθώς κατακερματίζεται
από τα ρεύματα της ανώτερης ατμοσφαιρας.
Πέρσι, είχαμε την τύχη να δούμε ενα τέτοιο ίχνος ενώ
το φώτιζε ο Ήλιος λίγο πριν από την ανατολή. Θεϊκό!
Τόλης.
Τόλη,
ακόμα το βλέπω μπροστά μου! Τι τύχη!
Ελπίζω να ξαναδούμε κάτι παρόμοιο και φέτος :mrgreen:
Και ένα αφιέρωμα στις Περσίδες, από γνωστό site που αφορά την εκπαίδευση. Έχει μέσα
και το Βαγγέλη Τσάμη αλλά και τον σύλλογο Σπάρτης. Ωραίο άρθρο, μακάρι φέτος να είναι πιο
φαντασμαγορικό από πέρσυ!!!!
http://www.alfavita.gr/artro.php?id=6562
Υ.Γ. Βαγγέλη έχεις φωτογένεια !!! \:D/ \:D/ \:D/ \:D/
http://www.astrothemis.gr
https://discord.gg/2DUPacrNfM
Πολύ κάλο το άρθρο, μόνο που υπέπεσε στο εξής (σύνηθες) σφάλμα:
Τα σωματίδια της ύλης είναι τα *μετεωροειδή*, ενώ το *μετέωρο*
είναι το φαινόμενο της εκπομπής φωτός κατά την είσοδο
των μετεωροειδών στην ατμόσφαιρα.
Με άλλα λόγια, δεν υπάρχουν μετέωρα στο διάστημα.
Τόλης.
ΥΓ: Ένας αστεροειδής δεν είναι τίποτα άλλο
παρά ένα μεγάλο μετεωροειδές.
Τόλη καλημέρα πολύ ωραία η παρένθεση σου για να μην γίνονται λάθει εγώ προσωπικά τα είχα
μπερδέψει!!! =D> =D> =D> Σε ευχαριστώ.....
Σημερα επιτελούς θα βγω για καταγραφη :mrgreen:
Να σς πω οτι χθες καθώς έφευγα απο την δουλεια με το αυτοκίνητο ειδα εναν πολυ φωτεινό Περσείδη, περιπου -5mag :mrgreen:
τι σου κανει η τύχη ε; να περιμένεις ολο το βραδυ εξω να δεις εναν -5 και να τον βλέπεις μέσα απο το αυτοκίνητο γυρνώντας απ'την δουλειά :D
Βασίλης Μεταλληνός
OO 16 1600 f4
www.metallinos.net
Καλησπερα, Χθες βραδυ πηγα για παρατηρηση και καταγραφη Διαττοντων, πρεπει να είδα περιπου 15 Διαττοντες μεσα σε μια ωρα αλλα περιπου οι μισοί ηταν σποραδικοί.
Εδω είναι δυο Περσείδες που έπιασα χθες: http://www.astrovox.gr/forum/album_showpage.php?pic_id=11033
Όποιος θέλει να φωτογραφίσει Περσείδες, Θέμη!!!
Βάζεις μια φωτογραφική (αν εχεις και παραπανω απο μια καλο θα ηταν) να πιάνει ενα μεγαλο τμημα του ουρανού, πχ με τον φακό στα 17μμ (ή οσο το δυνατόν μικρότερη μεγέθυνση) και το διάφραγμα όσο μπορούμε πιο ανοιχτό, εγω το βάζω στο f/2.8, εστίαση στο άπυρο ωστε να έχουμε σημειακά αστέρια και εστιασμένο διάττοντα. Χρονο εκθεσης μεχρι 1 λεπτο το πολυ, εγω βάζω 30sec ωστε να μην εχω trails στα Αστερια αλλα και για να μην "χαθει" ο Διαττοντας στην περιπτωση που φωτογραφίσουμε κάποιον. Αυτο ηταν...αφηστε την φωτογραφικη να βγαζει φωτογραφιες ολο το βραδυ μονη της και εσυ απολαυσε το θεαμα στον ουρανό δια γυμνού οφθαλμού :mrgreen:
Προσοχή στην υγρασία, καλο ειναι να εχετε αφηση την φωτογραφικά και τους φακους να ερθουν σε θερμοκρασία περιβάλλοντος.
Προσοχη στην εστίαση, μην κανετε αυτόματη εστίαση αλλα χειροκίνητη, MF (oχι AF), απενεργοποιήστε Stabilazer.
Το σιγουρο ειναι οτι θελετε ενα τρίποδο και ενα Remote control για την φωτογραφικη (δεν ειναι αναγκει να εχετε timer αφου μεχρι 30sec δεν χρειαζεται).
Καλο ειναι μην στοχεύσετε προς το ακτινοβόλο σημειο (δηλαδη προς τον Περσεα) αλλα απο την αντιθετη πλευρα αφου εχει θα πεφτουν οι μεγαλυτεροι διαττοντες αρα και περισσοτερες πιθανοτητες να πιάσετε εναν.
Καλο ειναι να μην μετακινήσετε την φωτογραφική σας ωστε μετα να μπορεσετε να κανετε φωτεινά Startrails.
Αν εχετε παραπανω απο μια φωτογραφικη στοχευστε σε διαφορετικό σημειο.
Και βεβαια υπαρχει η ρομποτικη βαση, οπου εκει θα παρουμε καλυτερο αποτελεσμα ως προς την βροχη αφου στο τελικο αποτελεσμ θα την εχουμε σαν βροχη, αλλα θεωρω οτι θελουμε φακους Fisheye ή τελος παντων φακου που να πιανουν τουλάχιστον τον μισο+ ουρανο. η ιδια λογικη με το παραπανω εως 1 λεπτο εκθεση, αλλα καλο θα ηταν εως 30-40sec.
Οσοι θελετε ριξτε και μια ματια εδω: http://www.astroexormisi2010.gr/files/Meteor_Workshop_Parnon.pdf
Βασίλης Μεταλληνός
OO 16 1600 f4
www.metallinos.net
Καλησπέρα σε όλους!!
Ένα μικρό κείμενο για τους Περσείδες για αρχή:
http://www.hellas-astro.gr/article.php?id=973&topic=meteors&subtopic=&lang=el
Χτες έκανα παρατήρηση από το οροπέδιο Λασιθίου κάτω από εξαιρετικό ουρανοί (και με αρκετό κρύο!!!) και είχε έντονη δραστηριότητα από διάφορες βροχές που είναι ενεργές.
Συγκεκριμένα για τους Περσείδες θα έλεγα ότι είχαν και αυτοί πολύ ενδιαφέρουσα δραστηριότητα κάτι που σημαίνει ότι πραγματικά θα είναι καταπληκτικό το θέαμα κατά την διάρκεια του μεγίστου.
Γρηγόρης
Καλησπέρα!
Βασίλη μπορεί να μην είναι αυτός που είδες ..αλλά κατέγραψε έναν ο Mikhail Maslov:
Ελπίζω να πετύχουμε και εμείς κανένα...
Γ
Παιδιά μια πρώτη γεύση από Πάρνωνα, ένα video με τα πρώτα μετέωρα 5 & 6 Αυγούστου.
Ναι, ήμουνα πάνω από την Πέμπτη!
Ήρθα χτες Αθήνα για να παραλάβω κόσμο, ημεδαπούς και αλλοδαπούς, και από αύριο Τρίτη ξανά Πάρνωνα και διάττοντες για άλλες 4-5 βραδιές. Ξαναπιάνουν δουλειά οι watec, αλλά και οι SPOSH. Απ' ότι είδαμε μέχρι στιγμής, προβλέπεται πανυγήρι με τα μετεωροειδή, και η πρόβλεψη του καιρού δε μπορούσε να είναι καλύτερη! Εκτός από Περσείδες, το menu περιλαμβάνει και αρκετά άλλα σποραδικά μετέωρα, SDAs και CAPs.
Κοιτάτε πάντα ψηλά!
Βαγγέλης
Πλάτων
Γρηγόρη o Mikhail Maslov βλεπω έκανε φοβερή δουλειά!!
Απίστευτος Διάττοντας!!
Βαγγελη μια χαρα σε βλεπω με το ufo capture :mrgreen:
Εμεις χθες ειδαμε αρκετους διαττοντες!!! Περισσοτερους απο 30-50 ο καθενας, αλλα βεβαια ήμασταν και 4-5 ωρες εξω!
Δυστυχως το Ufo δεν μου δουλεψει αφου η εικόνα που έπαιρνα ετρεμε σαν τρελη και τα έδειχνε ολα μπερδεμένα (σαν να Pal σε NTSC ή το αντιθετο) πρεπει να το ψαξω.
Εδω ενας Περσείδης απο της 5/6 Αυγ.
http://www.astrovox.gr/forum/album_showpage.php?pic_id=11043
Εδω ενας Αιγοκερίδης & Σποραδικός απο 8/9 Αυγ.
http://www.astrovox.gr/forum/album_showpage.php?pic_id=11053
Βασίλης Μεταλληνός
OO 16 1600 f4
www.metallinos.net
Βασίλη έχει ένα κουμπάκι (set) στο tab Input, στην πρώτη γραμμή, δίπλα από το πεδίο Video (που ορίζεις το input device)
Πάτα το κουμπί set όταν είσαι σε preview mode, και δες αν σε έχει στο NTSC.
Σε μένα πάντως είχε το NTSC ως default (!) και το άλλαξα σε PAL_B. Έτσι έπαιξε.
Μέχρι να βρω τι φταίει είχα τρελλαθεί!
Ή το άλλο, πρέπει νομίζω για όλες τις watec οι διαστάσεις της εικόνας στο Size Xi να είναι 720 Χ 576, και Fps=25. Αν θες πάρε ένα τηλέφωνο το Γιάννη, που έχει κι αυτός την 120Ν. Εγώ θα τον δω αύριο.
Ωραίες οι φωτό σου, όπως πάντα!
Βαγγέλης
Πλάτων
Βαγγέλη σε ευχαριστω, μεσα στην νυχτα και με το Dim της οθονης στο ελάχιστο και με night-vision δεν το είδα το set :roll:
Ελπίζω σημερα και αυριο να μας κανει την χάρη ο καιρος (γιατι χθες ειχαμε καποια συννεφα) ωστε να παρατηρήσουμε αρκετους Περσείδες!! :D
Επιτέλους κατάφερα να στείλω ενα σωστο Report στο IMO, εδω: http://www.imo.net/live/perseids2010/
(μένει να ανεβάζω και το report του κ.Μπούζη, το οποιο ειχε περισσότερους διαττοντες, αφου εγω στην αρχη επρεπε να κανω τις ρυθμισεις και να βαλω και το τηλε να κανει αστροφωτο)
αν και εχω καποιες αποριες σχετικα...
Στο Field (°) RA-DEC γιατι πρεπει να βαλουμε το ALT.-AZ. και οχι το RA-DEC ;;
Εαν δεν ειχα τιποτα να εμποδιζει τον ουρανο, το F το βαζω 1.00 ;;
Βασίλης Μεταλληνός
OO 16 1600 f4
www.metallinos.net
Hey!!! πράγματι το είδα σήμερα που έστειλα και εγώ δύο αναφορές...πολύ καλά!!
RA & Dec βάζεις απλά τα δηλώνεις το RA σε μοίρες και όχι ώρες (το Dec δηλαδή παραμένει το ίδιο!). Οπότε απλά μετασχηματίζει το RA σε μοίρες (360 μοίρες όλος ο ουρανός χωρισμένος σε 24 ώρες, κάθε ώρα δηλαδή είναι 15 μοίρε; διαφορά και κάθε λεπτό 0.24 μοίρες.)
Παράδειγμα, χτες χρησιμοποιούσα σαν κέντρο πεδίου το η Πηγάσου με RA=22h 40m & Dec 30deg. Άρα στο Dec βάζουμε 30, και στο RA = 22 * 15 + 40 * 0.24 = 339.6 μοίρες (βάζεις 340 μια και η ακρίβεια εδώ δεν είναι τόσο απαραίτητη).
Πολύ καλά η υπόλοιπη αναφορά. Το lm πως το υπολογίζεις, με τα τρίγωνα του ΙΜΟ ή κάπως αλλιώς;
Γρηγόρης
υγ ... οι αναφορές από τις δύο νύχτες που έχω κάνει..και έπεται συνέχεια! Πάντως έχει ένα ενδιαφέρον μια και παράλληλα με τους Περσείδες υπάρχουν και άλλες βροχές και γίνεται πανικός!!
(τελικά μόνο σαν συνημμένα μπορούν να τοποθετηθούν διαφορετικά γίνεται χαμός..)
081011_maravelias.txt
080708_maravelias.txt
Σε ευχαριστω Γρηγορη,
Καλα ρε'συ που τις βρήκες τοσες βροχες;; :o =D>
Εγω μολις ανεβασα και το Report του κ.Μπουζη :P
Βασίλης Μεταλληνός
OO 16 1600 f4
www.metallinos.net
Μόλις το είδα στο spacewather , έχει ζωντανή εκπομπή και μπορούμε να ακούσουμε τις περσίδες σε
live streaming!!
http://spaceweatherradio.com/
Καλή ακρόαση!!!! :mrgreen: :mrgreen:
Θεμη πολυ ενδιαφερον το Radio Perseids :mrgreen:
Λοιπον Σημερα είναι ΜΕΓΙΣΤΟ!!!!! :mrgreen:
Κανονιστε να ειστε ολοι ξεκουραστοι!!!
Εφοδιαστείτε με αντικουνουπικά!!!
Πάρτε μπουφάν, υπνόσακους και κουβέρτες!!!
Νερο, Καφε, Χυμό και κατι να φάτε κτλ.
Να σας πω οτι χθες ειδαμε αρκετους, αλλα περίμενα περισσότερους
εδω μπορείτε να δειτε εναν πολυ φωτεινο που κατεγραψα: Περσείδες 2010 - Πηλίδα Κέρκυρα
Επισης να σας πω οτι χθες ειδα εναν διαττοντα (περιπου 3.5mag) οποιος Εστριψε!! Ναι καλα διαβασατε! Αλλαξε πορεια οπως έμπαινε στην ατμοσφαίρα μαλλον ή μπορει να βρήκε πιο πυκνα ή αραια στρώματα αερος και να το αναγκασαν να αλλάξει πορεία... το θέμα παντος ειναι οτι ηταν πολυ περιεργο φαινόμενο να βλεπεις ενανδιαττοντα να στριβει και να κανει μεγαλη καμπύλη!! (περιπου 30° καμπύλη)
Βασίλης Μεταλληνός
OO 16 1600 f4
www.metallinos.net
Καλησπέρα!!
Σωστός! όλοι έξω!!
Τι εννοείς περισσότερους ??Πάντως χτες έιδα ότι η δραστηριότητα ήταν αυξημένη και μάλλον σημαντικά! Πάμε προς το μέγιστο...
Καταπληκτική φωτογραφία!
Η αλήθεια είναι οι δεν θυμάμαι να μου χει τύχει...δεν ξέρω αν μπορώ να πω κάτι πάνω σε αυτό , ίσως ο Τόλης αν έχει κάποια ιδέα.
live streaming!!
Πολύ καλό!! θα έχει ενδιαφέρον να το ακούτε το ράδιο αλλά μην απογοητευτείτε αν ακούτε και δεν...βλέπετε διάττοντες!
Η ράδιο καταγραφή είναι πολύ ευαίσθητη και πιάνει διάττοντες που δεν βλέπουμε με το μάτι (πολύ πιο αμυδρούς) και έτσι θα ακούτε ήχους και ..δεν θα βλέπετε. Από την άλλη δεν υπάρχει διάκριση σε βροχές, το ράδιο δεν μπορεί να καταλάβει αν ένας διάττοντας είναι περσείδης ή όχι, και επιπλέον πρέπει να λάβουμε υπόψην που είναι ο σταθμός. Γιατί σίγουρα δεν θα είναι στην Ελλάδα οπότε η δραστηριότητα που βλέπουμε θα είναι διαφορετική.
Γρηγόρης
