Καλημέρα παιδιά,
Θα ήθελα την γνώμη σας για το παραπάνω zoom προσοφθάλμιο. Υπάρχει κάποιος που να το έχει και να το χρησιμοποιεί; Δέν είμαι fun των zoom προσοφθαλμίων, αλλά χρειάζομαι να προσθέσω ένα στην συλλογή μου φθηνό και οικονομικό για χρήση σε φίλους ή σε παιδιά, και ιδίως σε πανέμορφες καλλονές με μάσκαρα. :cheesy:
Ευχαριστώ
Design: 4 elements in 3 groups
Focal length: 8-24mm
Mounting barrel diameter: 1.25"
Filter threads: Yes
Apparent field of view: 40 degrees at 24mm, 60 degrees at 8mm
Eye relief: 15mm (at 8mm) to 18mm (at 24mm)
Coatings: Fully multi-coated
Parfocal: Yes
Eye guard: Folding rubber
Weight: 7.9 ounces
Length: 4.25" (eyecup erect)
Diameter: 1.9"
Accessories included: Dust caps and a fitted plastic case
Country of Manufacture: Red China
Warranty: One year
http://www.chuckhawks.com/comparison_zoom_eyepieces.htm
The Celestron zoom is the bargain eyepiece in this comparison. Yet, despite its simpler design, its optical quality is (visually) very close to the other contenders, a tribute to good manufacturing. There is probably a lesson in there somewhere: execute a simple design correctly and it may be competitive with a complex design that is harder to manufacture. (If only we had access to an optical bench, so that we could "split hairs." -Editor.) The Celestron zoom appears to be well made, although not in the same class as the premium Tele Vue and Vixen zooms. The Celestron is not as smooth in operation as the premium eyepieces and it is noisier when the zoom ring is rapidly turned from 8mm to 24mm. However, it is much less expensive than the other zooms and performs well, making it the standout in the "bang for the bucks" arena. If your Chancellor of the Exchequer is a bit tight with funds, buy the Celestron 8-24mm zoom and never look back.
The goal of planetary imaging is not to acquire beautiful images, but to capture useful scientific data !
https://www.e-astronomer.com - Ιωάννης Α. Μπούχρας
Ναι τον αγόρασα εγώ πρόσφατα από το Πλανητάριο Θεσσαλονίκης εδώ στην Αθήνα. Την ημέρα αν δεν κεντράρεις καλά το μάτι σου βλέπεις 'kidney beaning" δηλαδή κομμάτια του πεδίου που μαυρίζουν (αυτό παρατηρείται όμως και με πανάκριβους nagler και Meade UWA, τη νύχτα δεν παρατήρησα τέτοιο φαινόμενο.
Είναι πολύ βολικός και ο μηχανισμός του ζουμ είναι πολύ απαλός σε αντίθεση με αυτά που γράφει το απόσπασμα που παραθέτεις. Ο προσοφθάλμιος όταν ζουμάρεις δεν κρατάει την εστίαση σε όλες τις εστιακές αποστάσεις ωστόσο η διαφορά για να εστιάσεις πάλι είναι μικρή.
Σαν bonus αν βγάλεις το λαστιχένιο προστατευτικό από κάτω έχει σπείρωμα να προσαρμόσεις T-adapter για φωτογραφική μηχανή.
Συνιστάται αβλεπί να τον αγοράσεις! Ίσως καταλήξει να είναι ο πιο χρησιμοποιούμενος προσοφθάλμιός σου! Σε μένα με το κοντό διοπτρικό Skywatcher 102/500 είναι συνδυασμός "δυναμίτης" στα 24mm είναι ερευνητής βρίσκεις κεντράρεις ζουμάρεις ακριβώς στη μεγέθυνση που θέλεις!
Είναι αγορά που δεν θα τη μετανιώσεις!
+1 και απο εμένα.Απίστευτα βολικό για τις δεσποινίδες με την μάσκαρα και το eyeliner. :cheesy:
Οι αναφορές χρηστών τον τοποθετούν ανάμεσα στον κινέζικο 21-7 (Skywatcher, Orion κλπ) και στο μέτρο σύγκρισης Baader Hyperion Zoom 24-8. Αν τον θες ωστόσο για δευτερεύουσες χρήσεις, η χαμηλή τιμή του και τα ευσύνοπτα φυσικά του μεγέθη τον καθιστούν προτιμητέο, ειδάλλως θα πρότεινα σαφέστατα τον Baader.
