alepohori Δημοσιεύτηκε Μάρτιος 20, 2008 Δημοσιεύτηκε Μάρτιος 20, 2008 Φωτογράφισε κανείς την περιοχή 2 μοιρών νότια του γ Βοώτη ,από το βράδυ της 19/3/2008 και έπειτα; Να ελέγξει τισ φωτογραφίες του! AAVSO Alert Notice 372 Possible naked-eye gamma ray burst detected (GRB 080319B)March 19, 2008 The intense gamma-ray burst GRB 080319B was detected in gamma ray, x-ray,optical light, and early indications by two automated cameras suggest thatthe optical afterglow of the burst may have briefly reached naked-eyevisibility (mag ~ 5.76, GCN 7445, Cwiok et al) within 60 seconds of theonset. It is highly unlikely the burst was caught visually, but it ispossible the burst may have been detected if any observers were monitoringthis area of the sky (e.g. for minor planet searching). The coordinates of the burst are: RA: 14 31 40.98 , Dec: +36 18 8.8 (J2000) Observers with any images of this field taken since 2008 March 19 0600 UTare urgently asked to check these images for optical transients. This includes wide-field images, sky and meteor patrol images, and any andall CCD imaging, filtered or not. Observers are also asked to obtain additional images of this field asthe afterglow decays. The object was at magnitude 16 less than tenhours post burst, but it may remain within range of observers with12-inch or larger telescope apertures and CCD cameras. If you are able to obtain any magnitudes, magnitude estimates, or limitsfrom your images, please submit them to the AAVSO with the name"GRB 080319B" or AUID "000-BFT-137". This AAVSO Alert Notice was prepared by Matthew Templeton. Δημήτρης Καπετανάκης CGCG108-138: Mag 15.5v, να τ'αφήσω; Πολλά τα mag Άρη! Το flickr μου
nickthegreek13_7 Δημοσιεύτηκε Μάρτιος 20, 2008 Δημοσιεύτηκε Μάρτιος 20, 2008 Μπορούν αυτές οι ακτίνες Γ να μας πλησιάσουν αρκετά με αποτέλεσμα να δημιουργηθεί (πάλι) Σέλας στη χώρα μας ;
Heal Δημοσιεύτηκε Μάρτιος 26, 2008 Δημοσιεύτηκε Μάρτιος 26, 2008 Όχι Νίκο, γιατί κατά τις εκλάμψεις ακτίνων γ δεν λαμβάνουμε στη γ φορτισμένα σωματίδια που θα συλληφθούν από το μαγνητικό πεδίο της Γης και να δώσουν σέλας, αλλά μόνο φωτόνια υψηλής ενέργειας. Η ακτινοβολία αυτή μπορεί να διαρκέσει το μέγιστο μερικά λεπτά και η κοσμολογική τους προέλευση (πριν φτάσουν εδώ διανύουν αποστάσεις λίγων δις ετών φωτός) τις κάνει πολύ αμυδρές για να προκαλέσουν κάποιο έντονο φαινόμενο στην ανώτερη ατμόσφαιρα. Το σέλας είναι κάτι διαφορετικό (δε σχετίζεται με την ηλεκτρομαγνητική ακτινοβολία απομακρυσμένων αντικειμένων σε μικρά μήκη κύματος), αλλά στην επιτάχυνση σωματιδίων (κυρίως ηλεκτρονίων και πρωτονίων ηλιακής προέλευσης) από το μαγνητικό πεδίο της Γη τα οποία συγκρούονται με τα μόρια της ατμόσφαιρας και δίνουν τα χαρακτηριστικά χρώματα. Ο λόγος που παρατηρούνται κοντά στους πόλους έχει να κάνει με το ότι εκεί καταλήγει το μαγνητικό πεδίο της Γης. Όσον αφορά τη συγκεκριμένη έκλαμψη, αναμένεται η μελέτη της να δώσει πολλές απαντήσεις στα ανοιχτά προβλήματα της αστροφυσική σχετικά με τις εκλάμψεις ακτίνων γ, που αποτελούν τα πιο φωτεινά αντικείμενα που γνωρίζουμε στο σύμπαν σήμερα.
