Περσείδες 2009: 17 Ιουλ. ως 24 Αυγ. Μέγιστο: 12/13 Αυγ.
πηγη imo.net
http://www.imo.net/news/perseids2009
Shower: Perseids (PER)
Activity: Jul 17 - Aug 24
Max Date: Aug 12
λo: 140°0
α: 48°
δ: +58°
v inf: 59
r: 2.6
ZHR: 100
Perseids 2009
Although the major northern hemisphere Perseids are badly affected by the last quarter Moon near their best this year, there is the possibility they may produce somewhat increased rates. The usual maximum is due around August 12, 17h30m-20h00m UT, but Esko Lyytinen suggests we may encounter the 1610 Perseid trail earlier on August 12, around 9h00m UT (λo = 139°661). This could produce activity additional to the normal Perseid ZHRs then of a few tens, maybe up to a hundred. Mikhail Maslov confirmed this but for 8h00m UT and with only 10-15 meteors per hour. Both reseachers further suggest that rates overall could be enhanced above usual by the proximity of the annual stream's core. The 19th century trail should pass roughly 0.003 astronomical units inside the Earth's orbit at λo = 139°499, so around 5h UT on August 12, though it may add less than 10 (according to Lyytinen) or up to nearly 100 (according to Maslov) to the ZHR at that point. Naturally, information to verify what takes place will be very valuable despite the Moon, so visual observers are encouraged to try to follow as much of what happens over the possible Perseid maxima as practical.
IMO.net Perseids 2009: visual data quicklook
http://www.imo.net/live/perseids2009/
πηγη iya2009.com
Perseid Meteor Shower Peaks August 12th, 2009
http://iya2009.com/perseid-meteor-shower-peaks-on-tuesday.html
very year in early August, we can observe the Perseid meteor shower (“the Perseids”). And it’s a fascinating sky event.
Here’s a beginners’ guide to what it is and how best to enjoy it. (Perhaps, impress your friends with these astronomy questions and answers!)
What are the Perseids and what is a meteor?
Every year in August, the Earth passes through rock and dust fragments left behind by the comet Swift-Tuttle, last time it came near the Sun. As these small particles collide with the Earth’s atmosphere, they burn-up, often creating a startling streak of light across the sky.
You can easily observe this and it can be a wonderous spectacle.
Why is it called the Perseid meteor shower?
The term “Perseid”, refers to the star constellation of Perseus.
View of Perseid meteor radiant point, above NE horizon after midnight
The meteors actually have nothing to do with the stars we see from Earth, as being part of Perseus. It just appears as though the meteors originate from Perseus.
In fact, the rock fragments are close to the Earth - that’s why they burn in our atmosphere.
They are very close, just a few hundred miles - not many, many light years distant like the stars.
But, if you trace-back the bright trails of meteors we see, they appear to originate from the stars of Perseus.
When can you see them?
The Perseid meteor shower actually starts in late July and runs to late August. However, the best time to view is around the peak.
It’s not precise, but the 2009 peak is expected on August 12th at around 15.00 hours UT. There is some uncertainty, so it’s very worthwhile to observe either side of this.
In particular for European observers, the hours of darkness either side the peak hours, may well prove more fruitful! So try the previous Tuesday night, as well as the night of Wednesday 12th.
And there is also a potentially prominent Moon to contend with. It will not set below the horizon until the early hours of the morning.
What equipment do you need to observe the meteor shower?
The good news is none! Just use your eyes.
It will help your observation if you give your eyes some time (say 15 minutes), to become adapted to the darkness.
Binoculars my also help, but on the other hand, they may restrict your view to a small part of the sky.
The meteors originate in the region of Perseus, but they may appear in view just about anywhere in the sky. Although, if you were to track-back their trails, you would get to Perseus.
Can they be measured, at all?
Yes. Keen astronomers count how many appear in a fixed period of time, in a certain area of the sky. This is expressed as a Zenithal Hourly Rate (ZHR).
We may expect around 100 streaks of meteor light across the sky per hour, at or near the shower peak.
Do watch out for them on Wednesday 12th August and during hours of darkness, before and after.
πηγη skytour.homestead.com
http://skytour.homestead.com/met2009.html#anchor_9
PERSEIDS
Predicted Maximum: Possibly multiple peaks on August 12 and August 13 (see text)
Moon: Last Quarter (major interference)
(radiant map from IMO)
WHEN TO WATCH: Wednesday morning, August 12, from about midnight until morning twilight gets too bright. Repeat on Thursday morning, August 13.
The Perseids are probably the most-watched annual meteor shower. The shower has a very long duration, from about July 15 through August 25. The shower is most interesting around its peak on August 12 or 13. The "traditional" peak of the shower would occur at around 18:00UT on August 12, in daylight for north America. However, Esko Lyytinen predicts enhanced rates earlier on August 12, with a possible peak around 9:00UT [2:00am PDT; 5:00am EDT]. And if by chance last year's unexplained late peak repeats itself, it could come on the morning of August 13 at 8:00UT [1:00am PDT; 4:00am EDT]. So, there are exciting possibilities for North American observers. Unfortunately, the Moon will be the Perseids' constant companion this year, rising late in the evening and culminating in the predawn hours. A high-elevation, dry observing site should be very helpful to get the most out of the conditions.
The Perseid radiant is above the horizon the entire night for observers north of latitude 32N, but it is fairly low at the end of evening twilight. Morning rates are generally better. Perseids are fast meteors and tend to be fairly bright on average. An occasional fireball is seen. Peak rates with the moonlight this year are likely to be 30-50 Perseids per hour, with a sprinkling of sporadic and minor shower meteors added to the mix. Mornings adjacent to the peak are usually worth watching, although the moonlight will be a hindrance this year.
πηγη earthsky.org
http://www.earthsky.org/skywatching/wheres-the-radiant-point-for-the-perseids
With the 2009 Perseid meteor shower due to peak on the mornings of August 12 and 13, people are asking, How can I find this constellation in the night sky, so that I can see the meteors?
One note before the excitement starts to build. This year, there will be a waning moon in the sky during the peak hours for the Perseids. So 2009 is not the best possible year to see this shower. You might try watching for meteors in the early part of the night. Or you might see some Perseids in bright moonlight – in the peak hours between midnight and dawn – on the mornings of August 12 and 13.
Moonlight is just a local problem. The meteors will be raining down as always, even if moonlight drowns them from view. The Perseid meteor shower is named for the constellation Perseus the Hero. It’s from this part of the sky that the meteors will appear to radiate. Today’s chart shows Perseus ascending over the northeastern horizon around midnight. That’s why this meteor shower is better after midnight: because after midnight, the radiant point for the shower is above the horizon. Just remember, the glare of the waning gibbous moon will wash out some Perseid meteors during the peak hours of 2009.
Notice the W-shaped constellation Cassiopeia just above Perseus. The constellation Perseus is faint, but Cassiopeia is noticeable and can help you find it. If you do see a Perseid meteor in 2009, and trace its path backward, you will find that it radiated from a point in the sky within the boundaries of the constellation Perseus. When the moon is out of the way, a meteors are raining down in all parts of the sky, you don’t need to know the whereabouts of a shower’s radiant to enjoy the shower. But people always ask! So here you are.
Many people look forward each summer to the Perseids. This shower always peaks at this time of year, and it reliably produces 60 or more meteors per hour at its peak, or an average of about one a minute. It’s great fun to give meteor-watching a try! It’s a chance to go to a dark site with friends and family – a chance to see some stars and enjoy the night air – and see some meteors. The 2009 shower will be troubled by the moon, but there’s still fun to be had, if you and your friends and family want to try a camp-out on the peak nights.
http://www.earthsky.org/article/earthskys-meteor-shower-guide
August 12, 2009 Perseids
And when we say August 12, we mean that morning … not that night. These typically fast and bright meteors radiate from a point in the constellation Perseus, and, like all meteors in annual showers, they cover a large part of the sky. The Perseids are considered by many people to be the year’s best shower when the moon is out of the way during the shower’s peak. Unfortnately, this year’s moon is not totally out of the way during the Perseids. The slightly waning gibbous moon rises around midnight – just as the Perseids start to pick up steam. Nonetheless, you should be able to catch some Perseid meteors before moonrise – and even after . The Perseids tend to strengthen in number as midnight ebbs toward dawn. Although not a favorable year, these meteors are often bright and frequently leave persistent trains. What’s more, enhanced activity may be in the works, so perhaps enough brighter meteors can overcome the moonlit glare to make this year’s production worthwhile. From late night on Tuesday, August 11 till dawn on Wednsday, August 12, a decent sprinkling of Perseid meteors may adorn this summer night, despite the pesky moon. Lie back and watch meteors until dawn’s light washes the stars, moon and planets from the sky.
πηγη popastro.com
http://www.popastro.com/sections/meteor/meteor-aug2009.htm
Shower of the Month: The Perseids
The usual Perseid maximum is due between 17h30m-20h00m UT on August 12 this year, and should produce typical healthy Perseid numbers, with Zenithal Hourly Rates (ZHRs) around 80-100. However, Finnish meteor analyst Esko Lyytinen has suggested the Earth may encounter two denser meteoroid trails earlier on August 12, around 05h00m UT (laid down at parent comet 109P/Swift-Tuttle's 1862 return, though perhaps adding only 10 or less to the ZHR then) and 09h00m UT (from the comet's 1610 perihelion, adding between a few tens up to a hundred to the ZHR). Material scattered around these trails may lead to somewhat higher than normal Perseid activity for most of August 12 ahead of the ordinary maximum as well. If correct, these timings will be about as unhelpful as possible for British visual observers, though radio observers should still manage to follow something of the better activity, interference permitting. Visual watching throughout August 11-12 and 12-13, if clear, would be scientifically valuable, and potentially more rewarding certainly, despite the added drawback of the waning Moon (at last quarter on August 13). The Moon will visible nearly all night on both occasions, from before the Perseid radiant (illustrated on the accompanying chart) is first usefully-observable at about 22h UT for Britain. Even so, Perseid meteors should be relatively frequent enough, and many sufficiently bright, to mean some should still be seen around then. Keen watchers will need to observe as much clear sky as comfortably possible, without looking towards the Moon (hiding it behind a wall or roofline will help). Perseids are swift, often bright, and commonly trained meteors.
PER Radiant Chart
Lower Perseid activity can be followed away from the peak date for most of the month, ending around August 24 (the shower began back in mid July). Moonless skies will be available only in the first week of August, and around new Moon on August 20 before the shower ends, allowing some coverage. Post-midnight observing is most favourable, as the radiant is higher in the sky then (it culminates around 06h UT). Activity builds only slowly, so ZHRs will likely still be around 10 by full Moon on the 6th, though rates are usually good to very good for a couple of days before the maximum plus a day or so afterwards, ZHRs tending to drop steeply once the peak is past.
Persids 2008
(ΟΧΙ 2009)
Πως θα καταλαβετε οτι είδατε εναν Περσίδη;;
Δειτε την φωτο και... θα δειτε!!
Βασίλης Μεταλληνός
OO 16 1600 f4
ΟΟ 12.5 1525 f4.8 NEQ6
TOA130 1000 f7.7 ΕΜ200
ED80 600 f7.5, Vixen9x63
2009年7月22號日食 - 2017 Aug 21
www.metallinos.net
  • Απαντήσεις 113
Βασίλη, θα παρακολουθήσεις καθόλου το φαινόμενο;
Δείτε λίγο εδώ
Θα προσπαθήσω να το καταγράψω για 3 νύχτες με την μηχανή σε piggyback. Απαιτείται "μονιποποίηση" του τηλεσκοπίου και της μηχανής και αυτό είναι ενα σοβαρό θέμα. Ελπίζω να βρούμε λύση για την ασφάλεια του εξοπλισμού. Το έχει επιχειρήσει κανείς;
Δημήτρης Καπετανάκης
CGCG108-138:
Mag 15.5v, να τ''αφήσω;
Πολλά τα mag Άρη!
Το flickr μου
Κάποιοι επιστήμονες υποστηρίζουν οτι το φαινόμενο είναι ίσως λίγο πιο έντονο φέτος... για να δούμε... , λογω της σελήνης επίσης ο ουρανός στο βορειο-ανατολικό τμήμα του θα είναι λίγο "ξεπλυμένος".
Πάντως τα βραδάκια 12-13 Αυγούστου μετά τις 21:00 ίσως απολαύσουμε όμορφο το θέαμα των διαττόντων κοιτώντας χαμηλά, βορειο-ανατολικά... :D
Θα οργανωθει καμία μαζική παρατήρηση?
Παρακαλαμε να μην βρεξει για να μην πνιγουμε...
παρακαλαμε να βρεξει να εχουμε νερο να πιουμε...
Noμίζω ότι θα γίνει αστροβραδιά στα Γρεβενά για αυτό το γεγονός την ερχόμενη Τετάρτη.Και θα διεξαχθεί από την Νομαρχία Γρεβενών... :cheesy:
Ο άνθρωπος προέρχεται από την αστερόσκονη των αστεριών και από την ανθρώπινη αστερόσκονη μπορεί να γεννηθούν νέα αστέρια....!!!!-(Μάνος Δανέζης)
:cheesy: :cheesy: :cheesy: :cheesy:
Βασίλη, πολύ ενδιαφέρον το θέμα.
Όντως αναμένεται αρκετά καλή βροχή Περσειδών!
Η Σελήνη ίσως εμποδίσει να γίνουν ορατοί κάποιοι αμυδρότεροι Περσείδες διάττοντες αστέρες,
αλλά το θέαμα από τα λαμπρότερα μέλη θα είναι απολαυστικό.
Βαγγέλης
Πλάτων
Το καλό που τους θέλω, Βαγγέλη! Θα θυσιάσω μια απόκρυψη αστεροειδή και ένα "ολικό" αμοιβαίο του Δία, για χάρη τους! Ο κύριος eclipse Ευφραιμίδης θα περάσει δύσκολες στιγμές αν το τηλεσκόπιό του είναι διαθέσιμο για οπτική πρατήρηση... Λυπάμαι! :twisted:
CGCG108-138:
Πολλά τα mag Άρη!
Το flickr μου
Αντε να δουμε τι περσειδες θα δουμε και φετος..!!Ελπιζω να το απολαυσουμε για μια ακομη χρονια!
:cheesy: :cheesy:
Φιλικα,
Βαλογιαννης Γιωργος
Ελπίζω το θέαμα να είναι εκπληκτικό..Ευτυχώς υπάρχουν και τέτοια γεγονότα να βγάζουμε το τηλεσκόπιο,γιατί με τόσες υπόχρεωσεις θα έπιανε σκόνη.. :roll: :mrgreen:
Τι να το κάνεις το τηλεσκόπιο στη βροχή των Περσείδων;
Άλλωστε θα καταγράφει την ολική έκλειψη της Ευρώπης!
Α να σου πω ότι θα δεις και απόκρυψη αλλά από μόνιτορ,
για να πάρω το αίμα μου πίσω!
Ποιό καλύτερο όργανο παρατήρησης από τα μάτια μας; :shock:
Πιστεύω οτι το θέαμα είναι ακόμη πιο εντυπωσιακό δίχως τηλεσκόπιο ή με τα μικρά μας κυάλια έστω...
Το φαινόμενο ειναι εντυπωσιακο με τα ΜΑΤΙΑ!!
θα πρεπει να εισαι πολυ τυχερος να δεις Διαττοντα με τα κυαλια!
Εγω προτιμω την παρατηρηση με τα ματια απο απομονομενες παραλιες (χωρις κοσμο και φωτα) ξαπλωμενος πανω σε μια κουβερτα στην ακρη της Θαλασσας :D
Να βλεπεις τον Διαττοντα να καιγεται στον ουρανο και η λαμψη του να καθρεφτίζεται πανω στην Μεσόγειο!!!
και η φωτογραφικη μηχανη "γραφει" μονη της.... 8)
Βασίλης Μεταλληνός
OO 16 1600 f4
www.metallinos.net
Καλά αν υπάρχει φωτορύπανση τι κυάλια τι μάτια τι τηλεσκόπιο... :roll: Τίποτα δεν βοηθά..Ας ευνοήσει ο καιρός και οι συνθήκες.. :mrgreen:
Παρά το γεγονός οτι υπάρχει αύξηση στην πτώση των μετεωρων (βλεπε πινακα imo.net http://www.imo.net/live/perseids2009/)
εγω δεν μπορω να πω οτι ειδα πολλα, ειμουν τουλάχιστον 4 ωρες στην παράλια αλλα οι Διάττοντες που ειδα ηταν μετρημένοι στα δακτυλα...
βεβαiα ευθύνη φέρει και η Σελήνη οπου δεν μπορουσα να κοιταξω τον Νοτιο ουρανο παρα μονο μακρεια απο την Σεληνη...και βεβαια απο τις 4 ωρες επρεπε να στήσω και τον εξοπλισμό για την καταγραφή (EQ6 με ED80 και Canon eos 30D να καταγράφει συγκεκριμένο μερος του ουρανου, και Canon eos 40D να κανει startrails)
Βεβαια σε καμία απο τις δυο φωτογραφικές δεν μπορεσα να πιασω κανεναν Περσειδη Την επόμενη φορα ελπιζω να ειμαι πιο τυχερος!
Να σας πω την αληθεια περισσότερο μου αρεσαν οι δ-Υδροχoΐδες αφου ειχαν ενα μεταξένιο άγγιγμα στον ουρανο σε συνδυασμό με το όμορφο χρυσαφένιο χρώμα τους εδιναν στον νυχτερινό ουρανό μια διαφορετική χροιά.
Βασίλης Μεταλληνός
OO 16 1600 f4
www.metallinos.net
Όταν υπάρχει αύξηση των μετεώρων σημαίνει κάτι αυτό?? :-k Και επίσης τα μετέωρα μπορεί να είναι υπολείμματα από κάποιον κομήτη και αυτό είναι περιοδικό φαινόμενο,όμως για πόσο θα διαρκέσει αυτό?Εννοώ όταν ο κομήτης Viela είχε εξαχνωστεί από τον Ήλιο τα υπόλλειματα που έμειναν έπεσαν στην Γη αλλά αυτό έγινε μόνο μια φορά και δεν ήταν περιοδικό φαινόμενο...Το ίδιο θα συμβεί και με τους υπόλοιπους διάττοντες? :-k Μπορεί να κάνω και λάθος.. :oops:
Απλα οτι πλησιάζουμε προς το μεγιστο της βροχης, εκτος βεβαια και αν υπαρχει μη αναμενομενη αυξηση ή μη αναμενομενη πτωση τοτε θα σημαινε οτι εχει γινει καποιο λαθος στις μετρήσεις και στους υπολογισμους διοτι ενω περιμεναν Χ αριθμο μετεωρων στο συγκεκριμενο σημειο της τροχιας της Γης πηραν Y μετεωρα (σιγουρα θα υπαρχουν και αλλοι λογοι)
Αν δεις παλαιοτερα reviews στο Internet ή στο imo.net θα δεις οτι οτι καποιες βροχες εδωσαν πολυυυ μεγαλυτερο αριθμο μετεωρων απο το αναμενόμενο ενω καποιες αλλες λιγοτερο.
Ευτυχως περνανε συχνα Κομήτες απο την τροχια της Γης με αποτελεσμα να εχουμε μια "ανακυκλωση" στις βροχες, για παραδειγμα οι Περσεισες ουσιαστικα ειναι απο (αν δεν κανω λαθος) 3 Κομήτες με κυριο "γονεα" Swift-Tuttle.
Βασίλης Μεταλληνός
OO 16 1600 f4
www.metallinos.net
Σας ευχαρίστω πολύ για την απάντηση σας!!Είσασταν πολύ κατανοήτος και κατατοπιστικός!!Ευχαριστώ και πάλι!! =D> =D> :mrgreen: :mrgreen:
Δεν κανει κανει τιποτα :D
(πω πω...τοσο μεγαααλο νουμερο δειχνει το 25... :P :lol:)
Βασίλης Μεταλληνός
OO 16 1600 f4
www.metallinos.net
Οι εκτιμήσεις κάνουν λόγο για πάνω απο 200 μετέωρα την ώρα!
http://www.spaceweather.com/
http://science.nasa.gov/headlines/y2009/31jul_perseids2009.htm
CGCG108-138:
Πολλά τα mag Άρη!
Το flickr μου
200 μετέωρα την ώρα?? :shock: Πωωω πάρα πολύ ωραία!!!! :mrgreen: Θα βγάλω τηλέσκοπιο αν ο καιρός το επιτρέψει!!! :cheesy: :cheesy:
Ελενη το τηλεσκοπιο ειναι Αχρηστο σε μια βροχη διαττοντων :wink:
Τα μόνα χρησιμα σε μια Βροχη ειναι:
Sleeping bag για να αραξεις στο εδαφος
ενα μαξιλαρι, πίτσα, μπίρες* και αρκετη υπομονη!!!
(καπου υπηρχε μια πολυ ομορφη φωτογραφια....)
*Για ολονυχτιες παρατηρησεις καλυτερα ειναι νερο και χυμοι γιατι με τις μπίρες τα μονα μετεωρα που θα δουμε είναι...της Καλαμπάκας!!! :lol:
Οσο για τα 200 μετεωρα ανα ωρα τα περισστερα θα τα "φαει" η Σεληνη :(
Βασίλης Μεταλληνός
OO 16 1600 f4
www.metallinos.net
Εμάς δυστηχώς όχι μόνο η Σελήνη θα μας τα φάει αλλά και η καταιγίδα που έχουμε!!!Δεν σταματάει να αστράφτει,από χθες όλο βρέχει...τι γκαντεμιά!!! :evil: :( :(
Μάλλον θα πρέπει να βγω από την πόλη μήπως και δω ξάστερη νύχτα... :cheesy:
Περσείδες 2007:
http://www.astrovox.gr/forum/viewtopic.php?p=61625
Πλάτων
Aπλά τέλειο!!!Η τέλεια απεικόνιση...για παρατήρηση διάτοντων...Και αν βρέχει τι κάνουμε?? :cheesy:
